2006 f250 with code P0674 please help
Discussion in 'All Other Diesels' started by darkbluef250, Feb 22, 2016.
  1. darkbluef250
    darkbluef250 New Member
    8
    0
    Feb 22, 2016
    San leandro ca
    I have 2006 f250 and this morning when I started it up the check engine light came on I have edge Tuner I read trouble codes it said this code P0674 something about the 4 cylinder glow plug circuit failure should I change all glow plugs please help.
  2. THEFERMANATOR
    8,820
    2,021
    May 9, 2008
    ZEPHYRHILLS FL
    I'm not really up on FORD's stuff, but it looks like the valve cover has to come off to do them. If so I would do at least teh 4 under that cover while it's off.
  3. 79jasper
    79jasper Active Member
    272
    134
    Nov 10, 2013
    El Paso, TX
    On the 6.0 they're actually on the outside, much like the 6.2/6.5.
    Right above the exhaust manifolds.
    The harnesses are common to give problems also. They can be had for not too much.
    Motorcraft glowplugs only.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  4. Will L.
    Will L. Well-Known Member
    6,904
    4,920
    Jan 25, 2013
    Boulder City Nv
    First clear code and see if it comes back. Is it starting ok, or stumbling as it starts?
    The wires going to the plugs are known to rub and short out. If $ is tight, open it up and inspect wires first.
    Otherwise like mentioned above do all 4 while your there. Heat shrink is your friend, or clean with brake cleaner and paint on electrical coating. Just spray cleaner on rag and wipe-don't spray cleaner into the engine.
    IMO when 1 side has a problem, the other side is not far behind. If you can do all 8 plugs and inspect the other side for chaffing, you can catch it before problem occurs.
  5. darkbluef250
    8
    0
    Feb 22, 2016
    San leandro ca
    It only gives me problems in the morning takes a while to fire up then when it does a lot smoke comes out the exhaust tip and I cleared the code it came back only when the truck is cold.
  6. darkbluef250
    8
    0
    Feb 22, 2016
    San leandro ca
    I can only put motorcraft glow plugs ?
  7. THEFERMANATOR
    8,820
    2,021
    May 9, 2008
    ZEPHYRHILLS FL
    Unless you want to do the job again. Many aftermarket glow plugs just do not hold up. MOTORCRAFT is probably made by BERU which is a premier glow plug manufacturer.
  8. darkbluef250
    8
    0
    Feb 22, 2016
    San leandro ca
    OK thanks for letting me know.
  9. darkbluef250
    8
    0
    Feb 22, 2016
    San leandro ca
    What kind of harnesse should I buy ?
  10. Will L.
    6,904
    4,920
    Jan 25, 2013
    Boulder City Nv
    Factory plug harness only if your going to replace it. The codes coming on from the cold requiring the glow plugs. They are not working - so you get the code and hard/rough start.
    Question is - wires, plugs, or both. You have to open it up to check the wires. If they're good then it's plugs.
  11. darkbluef250
    8
    0
    Feb 22, 2016
    San leandro ca
    OK thanks a lot for your help.
  12. JayTheCPA
    JayTheCPA Well-Known Member
    1,559
    748
    Jun 13, 2011
    Annapolis, MD
    Presuming the 6.0's GP's are outside the valve cover, can first check voltage at the #4 which will help isolate whether it is the wire or GP. If the voltage is good, this is not a 100% guarantee as the wire could have corrosion in it (and still carry voltage, but not allow enough amperage).
    In theory an Ohm meter can narrow down / isolate whether the GP is bad. There are specs out there somewhere in terms of the desirable resistance of a good GP. Basically high(er) resistance is good, low resistance is bad.
    If completely stumped (specifically the voltage and resistance look good), consider pulling the #4 GP to see what it looks like and go from there.
    Agree with the others, if the one GP is bad, best is to replace the whole lot.
  13. darkbluef250
    8
    0
    Feb 22, 2016
    San leandro ca
    Thanks for info
  14. NVW
    NVW Well-Known Member
    8,461
    843
    May 5, 2008
    Castor, AB.
    On our 6.5's glow plugs should ohm out at 1-2 ohms
  15. darkbluef250
    8
    0
    Feb 22, 2016
    San leandro ca
    I have a question I'm trying to buy the glow plug harness for my trucks it says it fit's Models built Prior to 12/18/06 And my truck was built 6/5 will it fit ?
  16. THEFERMANATOR
    8,820
    2,021
    May 9, 2008
    ZEPHYRHILLS FL
Share This Page
