1995 Gmc 1500 4x4 5.0 swap to 6.5
Discussion in 'Diesel Engine Conversions' started by 1995Gmc15o0, Apr 9, 2018.
  1. 1995Gmc15o0
    1995Gmc15o0 New Member
    7
    10
    Apr 9, 2018
    Canada
    Hey there, I have a 1995 Gmc 1500 4x4 I blew up my 5.0 the other day but have acquired a 1995 Chevy 2500 4x4 with a 6.5 turbo Diesel, I was wondering what it would take to swap it over? Frame on the 2500 is shot and the motor has 102,000km along with a rebuilt trans. If anyone has done this swap and could tell me what all is involved swapping between the two trucks! Thanks everyone!
    Sent from my SM-A520W using Tapatalk
    MrMarty51 likes this.
  2. MrMarty51
    MrMarty51 Well-Known Member
    1,171
    1,021
    Aug 1, 2017
    Miles City, Montana
    I`m not knowing what would be involved.
    At least You have the donor vehicle setting right there so it should not be too much, the 6.5 was available in the 1/2 tons so it would be a doable swapover.
    Welcome to the truck stop 95.
  3. 1995Gmc15o0
    7
    10
    Apr 9, 2018
    Canada
    Thanks for the welcome! And yeah that's what I was thinking, was just wondering if the complete front to back harness has to go in?
  4. THEFERMANATOR
    8,929
    2,222
    May 9, 2008
    ZEPHYRHILLS FL
    If you want to stay factory and run the electronic ds4 injection pump and the rest, then you've got your work cut out for you. In 95 GM made each wiring harness vehicle specific, so I can tell you the engine harness, underhood harness, fuse panel, both bulkhead plugs for driver and passenger are different, dash harness, rear harness, cluster, numerous modules, basically anything dealing with the engine, monitoring it, and so on is different. So you better hopethe diesel harness has every feature your truck has or else custom harness building is in your future. The dash harness has wiring for the low coolant module, apps, diesel ecm, extra wires for the cluster, underhood harness is diesel and trans specific, and even some things like ac pressure switches can be different for diesels. Now if you convert the 6.5l to a db2 mechanical pump, your biggest hurdle would be shifti,g the 4l80e trans or running your gasser tachometer.
    1995Gmc15o0 and MrMarty51 like this.
  5. 1995Gmc15o0
    7
    10
    Apr 9, 2018
    Canada
    I have the donor truck and my truck tore apart now, just tearing out the old harness for the 305 then putting the diesel harness through
  6. Will L.
    Will L. Well-Known Member
    7,288
    5,792
    Jan 25, 2013
    Boulder City Nv
    Take pics as you go. Good for future reference for yourself and fun show and tell for us. Also if you hit hiccups along the way we can see what you are lookin at exactly.
  7. 1995Gmc15o0
    7
    10
    Apr 9, 2018
    Canada
    This is what I'm done so far[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Jaryd, Will L. and MrMarty51 like this.
  8. MrMarty51
    1,171
    1,021
    Aug 1, 2017
    Miles City, Montana
    You are mooooving right along.
    Thanks for sharing the pics.
    Jaryd and Will L. like this.
  9. 1995Gmc15o0
    7
    10
    Apr 9, 2018
    Canada
    Yeah, I'm at a stand still today due to some rain but it's supposed to clear up tomorrow, so hopefully I'll get a lot more done, I'm staying dry today on the tractor stripping this old 88 f250 for scrap
    MrMarty51 and Will L. like this.
  10. 1995Gmc15o0
    7
    10
    Apr 9, 2018
    Canada
    This ol girl here[​IMG][​IMG]
  11. Will L.
    7,288
    5,792
    Jan 25, 2013
    Boulder City Nv
    Cool progress. Save the bumper, you want that for the airflow holes.
    MrMarty51 and Jaryd like this.
  12. THEFERMANATOR
    8,929
    2,222
    May 9, 2008
    ZEPHYRHILLS FL
    You will have to remove the entire dash from both trucks to swap the harness's. You will also have to get creative to swap in the hydro boost as your 305 has a vacuum booster.
Share This Page
