04 duramax need opinions
Discussion in '01-04 LB7' started by 3500 dually, Nov 12, 2015.
  1. 3500 dually
    3500 dually Member
    79
    3
    Mar 7, 2011
    Peculiar, Missouri
    My son is looking a GMC 2004 duramax 1owner. it is a very clean truck inside and out but the vehicle has 376,000 miles. They are asking 6500 for the truck. The truck all stock no add ons. What is everyone opinions on this truck with mileage and price? I know the trucks can run a lot more miles then this. Any help is appreciated. Thanks.
  2. btfarm
    btfarm 330,000 Worth and counting Staff Member Moderator
    16,582
    2,335
    May 12, 2008
    Sandwich, Illinois
    That's probably about right on price if it's clean. How long since the injectors were done is the important question.
  3. THEFERMANATOR
    8,983
    2,313
    May 9, 2008
    ZEPHYRHILLS FL
    Do you know if it's an LB7 or LLY. LB7 injectors are under the valve covers, LLY the injectors are outside the valve covers. It's alot of miles, and how it was cared for is everything here. Many have run alot more miles than that, and still going on stock engines, but if it has been beat on it could be an ightmare waiting to happen. With that many miles you need to at least plan on some front end work, probably u-joints, compelte brake job as rotors are probably gone with that many miles. BUT if it's been cared for most of this has probably already been done. The price is VERY dependant on how it's been cared for. It could be in line, or it could be way off.
  4. 3500 dually
    3500 dually Member
    79
    3
    Mar 7, 2011
    Peculiar, Missouri
    The engine is a LB7, I have not physically see the truck other than pictures of it. The interior as far as pics show is very clean and show very little wear including the seats. The tires looks to have 3/4 tread left with even wear and no chopping. I need to make a call to find out more info. The car fax is clean with one owner and one accident to left rear 1/4 when the truck had 11,000 miles. The bad thing is the truck is about 3 hours away from me. The outside is just as clean with no fifth or goose ball in bed. has had a tag behind the truck by looking at the bumper cover near the hitch.
  5. 3500 dually
    3500 dually Member
    79
    3
    Mar 7, 2011
    Peculiar, Missouri
    Well good people we have another duramax in the family. I thought pass on we did buy the truck and found out the engine in it has been been replace thus finding out that the lb7 only has 94,000miles on it. Found all the maintenance records in the truck which was well maintain. Just thought I update the results on what we decided. Thanks for the help.
  6. btfarm
    16,582
    2,335
    May 12, 2008
    Sandwich, Illinois
    Sounds good. Get some pictures.
    3500 dually likes this.
  7. tanman_2006
    tanman_2006 Just a farm kid...
    5,498
    509
    Feb 15, 2010
    Seiling, Oklahoma
    Being one owner, clean, and high mileage i doubt it was too badly beat on. Honestly surprised it needed an engine but if an injector hangs and melts a piston there isn't much you can do about it.
Share This Page
